does anyone know where I can get a pickup wiring diagram for:
SSH Strat with a push/push to enable the humbucker independently in the 4 and 5 postions as well as a push/pull coil cutter?
thnx in advance
You often have to take bits and pieces out of one diagram and insert them into another, when you start the cute stuff. I.E., start with a basic Strat wiring, locate a push/pull pot diagram.... translate your color codes etc. Yoink!
If I read what you want correctly (both positions 4 and 5=humbucker alone), you may need to use a "non-standard" 5-way switch with 2 x 5 "input" terminals (a "normal" 5-way has 2 x 3 "inputs" with positions 2 = 1+2 and 4 = 2+3). Otherwise I can't think of a way to do this without getting no middle pickup in positions 2 and 3 with the "humbucker only" push/pull position.
drewfz..
my bad.. I meant I want to add the humbucker to those positions giving both "neck/bridge " as well as all three pickups on.. I believe its refered to as "on-on"
