If possible warm the finish prior to application. If the aerosol's temp is higher than the ambient air temp you significantly reduce condensation.
Rattle cans can be heated in a pan of warm water. If you are using open spray gear you may need to get a little more creative, just remember that you are working with a volatile solvent and use some common sense about open flames or electrical systems (motors and such that may generate sparks.)
