What is this?
deepblue
Lads...
I got my first Warmoth body today.
Can anyone tell me why the top route has this split chamber?
I have had quite a few genuine Fender bodies, but never seen anything like this before.
To me, it looks like they machine in at an angle as well as down... to venture a guess, it probably gives the cavity more room to accomodate different options.  Is there a hole thru it so a ground can be added to the trem cavity?  I'm just guessing at what it could be, but obviously done on purpose, as all the bodies on the website have it.
That picture is at a weird angle, assuming that is the output jack route on a Strat body? In that case, that extra relief is drilled so as to accomodate the 1/4" jack type with a longer screw shaft (you have to use these on a rear route body) as well as  a regular 1/4" jack in the mounting plate.
Yes, as soon as you place the jack in there you'll get it  :sign13: ... the socket fits in there perfectly as you'll see.  :icon_biggrin:
Thanks guys. My Fender bodies dont have that and I never had a problem installing the jack.
Hey, at least I know what it is now.
Thanks again for the help.
Is the planet waves jack that much better? I looked at buying one, then I gave up caring about it.
It's gold plated, which probably doesn't matter much electrically but is attractive. It's stereo, which doesn't matter for probably 98% of the guitars/basses out there, but adds an additional set of sprung contacts to hold the plug more firmly. It's got a shield cover, which probably doesn't do much, but I suppose every little bit helps. But, what's truly practical about the thing is it uses two sprung contacts for both the tip and ring connections, so it's got a wicked grip on the plug and is less likely to become intermittent.
They're only $8.50 from Warmoth, and you have to buy a jack anyway. The little extra it costs is a drop in the bucket compared to what you're going to spend on the total project. As long as you have to solder up and install a jack, you may as well use one that's going to last forever and a day. It's a lot easier and faster to do it right the first time than it is to do it over a second time if you cheap out.
