aussieowner
I recently saw a product called Howard Feed-N-Wax on one of the FB Warmoth groups. I happened to be at Home Depot shortly after, and bought a bottle. It’s a blend of carnuba and beeswax, with orange oil, and is intended as a finish for raw wood.
I recently completed the build of my fretless Jazzmaster, and tried out the FNW on the neck. I sanded down to 1800 grit with regular sandpaper, and finished with 3M polishing paper down to around 4 micron. (I know this isn’t canon among neck finishers, but I find there is something about the way that 3M PP brings out the grain of the wood. JMO).
After sanding, I applied two coats of FNW, letting each coat penetrate the wood for at least 20 minutes, then buffing with a clean cloth, per instructions. After thorough buffing of the FNW, I finished with a coat of Gerlitz #1 carnuba wax and buffed thoroughly. The FNW darkens the wood a good amount, highlights the grain, and leaves the wood feeling like raw wood. And it’s dead simple to use, apply and buff like any wax.
I have a roasted flame maple neck to do next, can’t wait to see what it looks like after burnishing and the FNW.
Some pics before:
After
Some pics before:
After
