tylerncc
Hey all! So I just finished my first build (Warmoth body, neck, some hardware) and while I'm waiting for everything to settle in so I can do the final setup I'm thinking about an issue with the bridge. I used the Warmoth 6 saddle vintage bridge (https://www.warmoth.com/Vintage-Telereg-6-Saddle-Bridge-Chrome-P612C704.aspx) and it looks like the adjustment screws for the saddles are way longer than they need to be. It almost looks like its designed to allow you to use a 24 3/4 scale neck if you wanted or something. My intonation is close, but still slightly sharp across the board, so I know i need to pull the saddles back further, but its getting to the point that the adjustment screws are almost conflicting with the strings. This will be helped somewhat once I get the nut slots at the right height because I could lower the saddles a bit and get the screws more parallel to the strings, but it still seems excessive.
I was considering taking a Dremel cutoff wheel to the last 1/4"-3/8" on these, but thought it might be worth asking around here to see if anyone else has had a similar issue. Any advice is very much appreciated!
Also, I definitely have the build bug now. I need another guitar like i need a hole in my head, but I'm already planning the next one! Knowing this forum is here with so many people willing to offer expertise gives me more confidence that I can get through tricky stuff! thanks!
