spauldingrules
I have a Warmoth pro strat neck. I had 11's on it, and I have dropped to 9's. I need to loosen the truss rod more than the side adjust will allow. SO... what should I do? Tighten the side adjust, and then loosen the adjust screw at the base of the neck, and then fine tune with the side adjust? Do I need to put the side adjust in a certain position before I adjust the screw a the base of the neck?
Thanks!
TS
Thanks!
TS
