Last year I received my first Warmoth guitar, a VIP body with a Warmoth Pro neck.
Just a few months later the neck is twisted. Now it's not playable. Bass strings rattle from 1st fret and up to around 7th.
And no, I did not use any varnish as finish, just a hard oil (several layers of course). But I still can't believe it got twisted like this. To me this finish should be enough, it's hard and protects the wood from moisture. Haven't got any problems with other guitars.
What do you think I should do with the neck? Talk with Warmoth, try to fix it or just sell/throw it?
I have some other questions/complaints about Warmoth too, and I guess most of you are big fans of Warmoth so you might have good answers.
1) Why don't Warmoth hide the fret wire in the wood, so it looks like this:
http://upload.wikimedia.org/wikipedia/commons/3/36/Frets,_guitar_neck,_C-major_chord.jpg
I think it looks cheaper when you see the fret wire from above.
2) Why is the neck shortened compared to the fretboard? The fretboard on a 22 fret-neck looks extended.
3) The control cavity is unnecessarily big in the VIP body. It gives the body more resonance, which not sounds good to me if you want a solid sound. Is it the same for other Warmoth bodies?
4) I don't like that the Warmoth Pro neck (at least the Standard thin) has a "hump" at the back of the neck between the head and 1st fret. Why not have it even and smooth like other necks? And is this something particular with the Warmoth Pro neck or do they shape them all the same there?
5) I'm thinking about buying a new Warmoth neck but then I have to buy one with a finish (as I want warranty), how is the nitro?
Thanks in advance.
Thanks in advance.
