If you're not specifically looking for a TOM, the Gotoh and Wilkinson tremolos both have 54mm spacing, as does the Floyd Rose. In some places it says 53mm for some of these, but if you look at the actual spec it's 54 (10.8mm between strings.)
I'm guessing that if the top is curved where the bridge sits, this means that bridges that have a flat base like a Strat hardtail wouldn't work.
You can get this Schaller TOM style that has adjustable string spacing, but you may need to use an adapter stud/insert to fit in the TOM stud holes Warmoth provides: https://schaller.info/en/stm/1208
