PylonRacer
What are the pros and cons between the vintage and double expanding truss rod? Do the vintage rods really need to be adjusted that often?
HA! that's an AM STD Strat, so I guess I don't want another Biflex truss rod LOL! :laughing3:bpmorton777 said:if the neck you have is as twisted as the one in your picture, yes, you need to adjust your truss rod :laughing7:
Brian
Thanks for the tip. I was considering the vintage top adjust. I couldn't imagine having to take the neck off just for a truss rod adjustment!reverend mikey said:Personally, I'm tired of messing with vintage truss rods that require removing the neck from the body to adjust...attach neck, tune, repeat as needed...aaagh!!!
Ordered my latest with the truss rod adjustment at the neck, even though I was going for a '62 vintage look...it's just not worth it to be totally correct. (I realize this is a different issue than single versus double truss rod, but it's an important factor to consider when you 'build' your guitar in your head before you order.)
Hehe, nice bit of trivia there.stubhead said:I personally like more weight in the neck, I think it leads to more evenness of tone between the strings and better sustain. Large headstocks, a big-profile shape like the boatneck, heavy tuners and the double trussrod are all ways to put weight in the neck. Of course, you have to consider balance, but I want tone first then I'll worry about what else I have to do. Not having to adjust your trussrod at least twice a year is an added benefit.
The real vintage freaks are probably correct that if you want a fifties-sounding guitar, you'd want a fifties-construction neck, but I'm glad the construction has been improved..... I drive a Toyota instead of a Model T and my computer runs on transistors instead of the good ol' tube ones, so what do I know. :dontknow:
(There didn't even used to BE vintage Fender basses for sale cause all the old single-action bass necks were WARPED, but then the counterfeiters figured out they could make just as good a profit from faking basses as from guitars and now vintage basses are everywhere.... At any given point, there are roughly TEN TIMES as many old Fenders and Gibsons for sale as were ever even manufactured.) :toothy12:
stubhead said:(There didn't even used to BE vintage Fender basses for sale cause all the old single-action bass necks were WARPED, but then the counterfeiters figured out they could make just as good a profit from faking basses as from guitars and now vintage basses are everywhere.... At any given point, there are roughly TEN TIMES as many old Fenders and Gibsons for sale as were ever even manufactured.) :toothy12:
PylonRacer said:Thanks for the tip. I was considering the vintage top adjust. I couldn't imagine having to take the neck off just for a truss rod adjustment!reverend mikey said:Personally, I'm tired of messing with vintage truss rods that require removing the neck from the body to adjust...attach neck, tune, repeat as needed...aaagh!!!
BTW nice picture. Are those aged knobs w/ a mint pickgaurd?
