Hi
My new neck has a substansual up bow in it when unstrung. I measure with notched straightedge and feeler gauges, and the largest gap about 6 - 8th fret is about 0.24. When I tighten the trussrod, the gap does not get alot smaller, I read about 0.22.
I can´t move the trussrod alot. When I have turned it about 1/2 a circle it gets very stiff and I dare not to force it further. Should a new trussrod have enough lube in it to turn? I don´t know how I can get the nut out to lube it, because the hole is very small, and I would know how to get it out.
When I string the guitar, the neck gets even more up bow in it. I can see how the frets from 17 and upwards (the tounge) gradually go upwards and are way higher and closer to the strings then the frets below 17.
Any tips? I have never seen so much up bow in a neck, and I own many guitars. And I don´t know why the truss rod wont turn more then just about 1/2 a circle.
When I turn the rod in the other direction, the nut gets loose for a while and when I turn further it tightens again, but creates more releaf.
