Hey guys,
As previously posted, I completed my first Warmoth build earlier this year. The original neck I put on the body was fitted with the LSR nut. When I installed it, I only added a single shim on the nut and the result was that the guitar action was perfect. The bridge (Wilkinson trem) was pretty much screwed right down on the posts. The guitar stayed in tune very well (Wilkinson trem, LSR nut, Sperzel locking tuners). Unfortunately I didn't like the fret wire on this neck, so I bought another Warmoth neck from the showcase. Same specs as the original except for the wood, the fret wire (obviously), and I went with a TUSQ XL nut.
I'm finding with this new neck that the bridge has to be set with the posts backed out a bit for the strings to clear the frets, and it floats fairly high over the body. I'm also finding that the action is still fairly high... any lower and I start to buzz at the 12th fret and higher. Seems to me that the action at the nut is high on the bass side too. Also, really going out of tune easily... like a single dive-bomb and my low-E is out. So even with a new neck built to the same specs as the original neck, the only difference is the nut ... and I'm thinking this might be the issue.
Wondering if filing down the string slots might help to lower the action at the nut and maybe widen the slot so the strings glide a little easier.
Any thoughts or suggestions?
Thanks
Thanks
