jackson929
I know this has probably been beat to death here and I did do Google searches.
I in my first build (and totally addicted). I am going to lacquer the headstock and tung oil the neck from the nut down with pure tung oil.
It sound like a cut the tung oil 50/50 (I am going to use mineral spirits because it is on hand) for a few coats, buffing each coat after application. Then on the final coat or 2 use 100% tung oil. Does this sound correct?
Then my main question is... Since the neck is not bolted on yet. Do I oil all the parts which will connect into the neck pocket? Or not touch the entire section at all? TIA
EDIT: Also I am aware of the warranty factor.
