Hi guys, I'm working on my first build and wondering about what order I should do things.
Right now, I've got all the wiring done, but the bridge still isn't installed (although the pole pieces are put in, I forget what these are called but it's a tuneomatic bridge). The neck still isn't on the guitar. From what I can tell, my remaining steps are: screw in the neck, adjust truss rod, install the bridge (it's held in by string tension), put on strings, adjust action, adjust pickup height. And if need be, I may need to file the nut or file down some frets. I'm just at a loss for the order to do these steps. I'm thinking the order I listed them in should be okay, but I'm not really sure. Anyone have some suggestions for a newbie at this? I want to do it as straight-forward as possible without having to go back and change what I've done before.
Any tips would be great, I'm planning on screwing on the neck tomorrow. I guess my main problem is that I'm unsure how I can know if my truss rod has been adjusted right without the strings on the guitar, but then I don't think I'm supposed to have strings on until the truss rod has been adjusted. I'm using gauge 12 strings also so I'm worried if the truss rod is left as is then it could warp the neck due to the high tension of the strings.
