Dear All,
I'm building a JazzMaster with p90s and a Callaham vintage trem.
I will use this guitar with the C Pentatonic Tuning (C G D A E G low to hi) and I'm evaluating possible intonation problems using a vintage Callaham tremolo bridge with strings bigger than the standard.
I read from several sources on the internet that the "standard" position for the six bridge holes (for a "vintage" vibrato bridge in a stratish guitar with 25 1/2 scale) is at 25 1/4' distance from the nut. Can you confirm Warmoth body/necks use this (or other) exact value?
Please understand me: I have no doubts about the quality standards of Warmoth, I only need to have precise info to carefully plan the routing to ask you.
Most of the Strat I saw have incorrect placement of the bridge, which is usually closer to the nut as it should be. Having a low C to compensate, this would be a problem, so I need to be sure that the Warmoth routing will be exact...
Thank you very much for your answers!!!
Best Regards
Best Regards
