Trembucker Routs and Seymour Duncan Pickup Covers
mookyshoots
Folks,
I need to order a Strat pickguard in a HSH config, but I can't find any dimensions for the various humbucker routs on Warmoth's site. The humbuckers will be Seymour Duncan '59s with nickel covers (bridge pickup is a trembucker). I know that SD for whatever reason uses a wider bobbin on their trembuckers, so that's why I'm asking. Will the standard trembucker rout (not the fat one) accommodate the covered pickup or will I still need to file it to make room?
Thanks
mookyshoots said:
...but I can't find any dimensions for the various humbucker routs on Warmoth's site.
The dimensions are there.  You just need to scroll down a little further: http://www.warmoth.com/Pickguard/StratPickguard.aspx
If you're using a Trembucker with a cover, you probably want the Trembucker rout for the bridge and a Humbucker rout for the neck for the regular spaced pickup.
Doh!!!
Thanks for pointing that out. I completely missed the page scroll. I stayed up a little later than I should have.
