justsomeguy1
I'm wondering what peoples thoughts are on using a treble bleed vs a 50's wiring scheme.
I will be wiring a custom set of pickups (based off of a Super Distortion [bridge] and PAF Pro [neck]) and trying to decide on which to do.
I understand the difference in that with 50's wiring you retain some high end when rolling off the volume, but you also experience change in volume when using your tone knob. I've also seen posted a couple of times that sometimes this method doesn't work well in high gain situations, though I'm unsure if that is true or not given the scarcity in which I've seen it posted.
I also understand that a Kinman circuit treble bleed retains high end as well but can sometimes be TOO bright and tinny when volume is rolled off too much, and also you need to have the correct value components.
Has anyone experimented with both using similar output/constructed pickups before?
