Steve St.Laurent
Been thinking about building a travel guitar for quite some time. I've looked at what's out there and am not really happy with any of the off the shelf offerings. Also, being completely spoiled with Warmoth I can't see not having the same comfort/feel with my travel guitar. So - I think I've come up with a good solution and figured I'd run it through the brain trust here before moving forward with it. I've attached a mockup. Basically I'm going to start with roughly a tele shape but shortened length wise and with the top horns cut down and the cutout made deeper so that I can access the 24th fret better. 24 fret neck and using a Steinberger style headless adapter for the ball end of the strings (pic attached). Then for the bridge using a TOM style bridge and use these Steinberger tuners ( http://www.stewmac.com/shop/Tuners/Guitar,_solid_peghead_tuners/Steinberger_Gearless_Tuners.html ) that just go straight up. Route out a cavity on the back side of the body for the tuner knobs so that they are recessed in the body and then the part of the tuner that the strings attach to will stick out the top of the body below the TOM bridge (they are black on my mockup).
Another option would be to use the Steinberger bridge: http://headlessusa.com/6-string-tremolo.htm or there are cheap knockoffs that are fixed bridges - but looking at the pics of them the quality kind of scares me. I'm not concerned with having a tremolo on my travel guitar and kind of like the idea of having it be a little more rugged. Those gearless tuners look to me like they would be a lot more robust and less to go wrong. I thought about using regular locking tuners as well but when I mocked it up there doesn't look to be enough room to fit them in (2 lines of 3 L/R tuners).
I'll probably embed something like a vox headphone amp into the back side of the body which is why I like have a slightly larger tele shaped body. I'll be able to switch to the headphone amp or to a regular output to an amplifier - it would just be nice to have it all built right in for practicing.
Don't pay attention to the body finish or fretboard, etc. I was just doing a quick mockup in photoshop to get the general shape, etc and see how it would work out. Also, this is the full width body top to bottom with the curves at their appropriate places and sizes so it should feel pretty close when sitting and playing with it on my leg, etc. I'm really looking for something that is going to play/feel like a full size guitar but be easier to carry around when traveling - tossing in the trunk of my mustang, etc.
