On my first guitar I kept the switching super simple. My current build is HSH and I'm being a glutton for punishment using both a Push/Pull Volume and a super switch.
My question is actually simple. In positions 2 and 4 I'm considering leaving the Middle Pickup out of the tone loop. So the tone pot will only affect the Neck or Bridge (north/south depending on up/down). Bridge tone pot will control Middle tone in position 3 . Check the diagram and the dotted purple line. If I connect the dotted line, then 2/4 will also control tone of the Middle pickup. If I leave dotted off, then 2/4 will only control the buckers tone.
I was just wondering if leaving the Middle pickup full on in conjunction with the split buckers is a better choice. Have any of you done it this way? I did a google and couldn't find audio examples.
