TConnelly
Greetings all!
I've been wanting to do a complete build since I got a Rosewood over roasted maple neck for my Stratocaster last year.
Well the opportunity presented itself so I picked a chambered standard Tele in Tobacco sunburst out of the showcase and ordered a rosewood over roasted maple neck with stainless 6105 frets and mop face and side dots in standard thin and 10"/16" radius. The whole works arrived in under 4 weeks.
For pick ups I got a vintage broadcaster set from Seymour Duncan and a four way switch.
Made pretty good progress this weekend. Rounded the fret ends and polished the frets a bit. Mounted the tuners nd mounted the neck. First I sanded the little ridge of finish out of the neck pocket and sanded the neck plate flat on the back side on a chunk of plate glass. Sanded the bridge and control plate as well. At first I mounted the neck with a 0.25 degree shim from StewMac. As it turns out it wasn't needed. After the neck was installed I installed the bridge and strung up the D and G strings with a length of 20lb test fishing line just to check neck alignment and action height. Perfect! Right on the money! In fact the fit & finish on these parts is perfect. Couldn't be happier! The only snag I've run into is that I bought the pots from StewMac but I bought the knobs from Warmoth. Didn't think to check the specs so the holes in the knobs are way too small. Oops! If that's the only issue I run into I'll be thrilled !
I included a few pics of the process of mounting the pickguard and control plate and one of the progress so far.
Cheers...................Todd
