I've started quite a few threads on here about tuning problems I've had with my Warmoth Strat. I've changed necks, Tuners, installed Graphtech nuts and saddles, etc, etc, I won't go on.....
Problem got so bad I recently resorted to buying a Fender body as I thought maybe it may be the body wood (chambered Swamp Ash), on my Warmoth. (clutching at straws :icon_scratch
that was effecting the tuning. The Fender body weighed a ton in comparison, though it did sort the tuning probem out.
During the week I was removing the Warmoth neck to give the whole thing a good clean. I noticed the neck screws didn't fall out of the Fender body like they did with the Warmoth body, and were snug in threads in the neck pocket. Got me thinking, a couple of members on here suggested neck movement may be causing the tuning problem..hmmmm. Got out the Maple tooth picks and carefully superglued one into each neck pocket hole. Put the neck plate back on, installed the screws with a screwdriver this time as they didn't push through freely like before, restrung her, and I swear this Strat has barely lost tune in the 4 days since. By golly I think I've solved the problem. :cool01:
Do all Warmoth bodies come with over large neck pocket screw holes, or was it just mine? When you sit down and think about it, if they do it sure can't help with neck stability. Peace to all! :headbang:
