I'm putting together a tele project and considering putting the output jack in the control plate. I would use a 3 hole control plate like the ones seen here https://rockrabbitguitars.com/shop/triple-telecaster-control-plate/ .
Is there any reason not to do this?
Never thought about doing that. Might have a problem when sticking in your jack but you’ll never know for sure till you try. The worst that will happen is you’ll have extra parts. Where will you put the kill switch?
While the Shadow killpot does what it’s supposed to, it has a tendency to break pretty easily. I have several and used them in two guitars and they have all failed eventually.
So if you want the killswitch functionality in your guitar I would use an ordinary killswitch and have the output jack at the side as usual instead.
This is an excellent point. I have a tele and the two small screws holding the control plate down are going to strip out pretty quickly with a jack. Your eventually going to rip out the plate unplugging one day.
They are the same size screws that hold in a Strat jack plate. My issues is you would need right angle plugs or eventually the jack will get in the way and, if hit, torque the jack plate.
