V vtpcnk Hero Member Messages 743 Aug 31, 2009 #1 in warmoth tele bodies are the routes between the control cavity and the pickup cavities already routed? or is that to be done by the buyer or the tech that the buyer goes to? appreciate the feedback.
V vtpcnk Hero Member Messages 743 Sep 1, 2009 #3 any pictorial representation of how the internal routing is done between the pickup cavities and the control cavities on a tele thinline?
T tfarny Master Member Messages 4,481 Sep 1, 2009 #4 It's just a hole they drill from pickup cavity to control cavity. Not much to look at.
Super Turbo Deluxe Custom Epic Member Messages 8,318 Sep 1, 2009 #5 Unlike the Strat, where all pickup wires must go through the bridge p'up route, each one has it's own path to the control cavity.
V vtpcnk Hero Member Messages 743 Sep 1, 2009 #6 so you pretty much need two holes - from the control cavity to each pickup cavity?
Super Turbo Deluxe Custom Epic Member Messages 8,318 Sep 1, 2009 #7 vtpcnk said: so you pretty much need two holes - from the control cavity to each pickup cavity? Click to expand... We'll yeah, but they drill 'em.
V vtpcnk Hero Member Messages 743 Sep 2, 2009 #8 are the holes visible here - in the side shot : http://www.warmoth.com/Showcase/ShowcaseItem.aspx?i=pt1499&Body=2&Path=Body so from where is it drilled? from the pickup cavity or control cavity? it looks like a long way from the neck to the control cavity though.
V vtpcnk Hero Member Messages 743 Sep 2, 2009 #9 the issue is that i have a thinline body which came without the interconnecting holes between the pickup and control cavities. so is the routing normally done before the top cap is glued in. or after the top has been attached?
Super Turbo Deluxe Custom Epic Member Messages 8,318 Sep 2, 2009 #10 Don't know when it's done, but always call them first and let them resolve any issue.
