clearerphish
You have 24 hours or Friday is New Guitar Day.
http://www.rondomusic.com/al3100tredwidegoldhw.html
Agile AL-3100 LP copy
Extra wide neck for comfortable playing - Width of the neck at the nut: 1 3/4"; at the 21st fret: 2 1/4"
Solid mahogany (not a multi-ply!) arch top body
Graph Tec NVS 2 Bridge with string saver saddles.
High quality Book-Matched Flame Canadian Maple Top (100% real wood top-not a photo top!)
Triple bound body, and headstock. Single binding on neck.
Gold die-cast Grover tuners with 18-1 turning ratio for ultra fine tuning (Model 102-18N)
Two Type V Alnico humbucker pickups for warm, tradional sound
The AL-3100 comes with improved wiring, improved pots (now higher voltage with brass shafts for reduced noise) and an improved pickup selector switch
Two volume and two tone controls, plus a three way pickup selector switch
One piece Mahogany set neck with 13.7" (350mm) radius neck for fast play and adjustable truss rod
Ebony fretboard with 22 Jumbo frets and real Mother-Of-Pearl Trapezodial inlays
The AL-3100 features D'addario strings installed at the factory and a professionally cut Graph Tech Nut
Individually hand filed frets for professional feel and playability
Neck taper/thickness at the 1st fret: 21.5 mm; at the 12th fret: 23.5mm
Overall length: 40"; Scale length: 24.7"
Body thickness: 2" at edge; Width at the widest point: 13"
Bridge pole spacing is 3", and the Tail piece pole spacing is 3 1/4"
Actual Weight is only 10 lbs
