justsomeguy1
Using an HH pickup configuration with a 5-way super switch I would ideally like the following:
1. Bridge humbucker series
2. Bridge humbucker parallel
3. Bridge and neck both in either split or parallel
4. Neck humbucker parallel
5. Neck humbucker series
Every wiring diagram I come across that has the same position 2 and 4 setup, the position 3 is always bridge and neck in series.
Also every diagram I come accross that has position 3 as bridge/neck both split, positions 2 and 4 are also split.
Is what I'm trying to accomplish with position 3 having bridge/neck both either split or parallel even possible if positions 2 and 4 are parallel wirings?
