TBurst Std
Ran out of my normal wires. Ordered some from the W. Their shielded wire is much different than the braided shielded wire I have used. The outer shield is much finer, and is insulated.
Have you used it? If so can you confirm that I should NOT be using the outer braid as a ground, say to the jack? Doesn’t seem near sturdy enough. Then again it is much thinner, so I can run 2 wires instead.
