Timmsie95
I know i'm not the first to think of this idea, but I figured I'd bring it up, just because.
So everyone hates soldering the ground wire to the bridge claw, then to the back of a pot, right? Well there's a solderless solution. Find some crimp-on terminals, like these:
Take your ground wire ends and tin them, and crimp the terminals to the ends (I use the fork-style/spake lug ones for ease of removal)
Then, slip one end behind one of the screws for the bridge claw. That's that end taken care of.
For the other end, I use the ring terminals to ensure it stays a bit better, and simplu slip it over the shaft of your tone/volume pot, then put the pot through the pickguard, so the terminal is between the pot and the pickguard. This way, you're free to swap out a pickguard more easily, and your pots look cleaner!
Some people may argue that there's not enough contact, or it won't ground as well, but in my experience, it works just fine, and looks a hell of a lot better. :icon_thumright:
