I cherish each and every last micron of fingerboard real estate, particularly on the treble side. Noooo.
This is the fundamental problem: many necks are simply too narrow to allow for a comfortable rounding of the fret ends
and boards. The worst problem came with the vintage-spec Fender Telecaster and Stratocaster bridges on a skinny narrow vintage neck*, and that problem is exarcerbated if you install bigger frets, then expect to be able to put a nice bevel on them.
The 35 degree bevel from the Stew-Mac device is way too much for my preferences, that's just trying to apply a quickie solution to two problems: One, factory fretwork often sucks; two, good fretwork is really, really time-consuming. I'd rather order fret ends straight up than try to start with already over-beveled frets - this complaint showed up from time to time with Warmoth, but I haven't seen that one on the board for a while, so maybe they got more consistent. (Hey! Thnx!) Besides simple quality control and desirable features, I think one of the main reasons that Schecter & Ibanez do so well is because they're
NOT mentally "stuck" with vintage specifications, which are simply no longer adequate for the way electric guitars are played in 2011 (or 1969, for that matter).
I consider "rolling" the wood in-between the frets, without reshaping the fret ends, to be quite deranged - you're making the frets
more stickery/slicery/bulgier relative to the wood, not
less.... There is really no wham-bam substitute for:
A) A neck wide enough for the chosen bridge (Both Warmoth & USA Custom offer X-tra wide necks, though using two different solutions);
B) Frets and wood beveled to the same, individually-preferred amount;
C) Painstaking, slow, pain-in-the-ass, 88-corner fretwork.
*(Boy, Leo sure snorked the bipper on
that one, huh? What a zub.) [z]
insert ducking behind shield emoticon here[/z] :headbang1:
