Hello
do you know if I can find the information about the actual size of each pickup routing offered by Warmoth?
And do you know at least what is the size difference (if any!) between the standard humbucker and the wood mounted version?
Thanks!
Standard humbucker and Wood mounted only differ where the standard has deeper pockets for the longer adjustment screws, which is useful for either ring mount or pickguard mounting.
Which, if you are trying to obtain the actual length/width of them, the StewMac routing templates are pretty close if not dead on for your typical guitar Humbucker/Single Coil routes.
