K
KainThornn
What's the general consensus on these? The head style I want (KWS reverse right handed) isn't available as a tilt back.
KainThornn said:What's the general consensus on these? The head style I want (KWS reverse right handed) isn't available as a tilt back.
KainThornn said:SS frets are a must have item!
KainThornn said:Thanks for the replies! Once the end adjuster was set, was there much need for any for any further adjusting via the side adjuster? I'd get a tilt back head type neck or left handed neck just to have the adjuster in a familiar place. I have a set of 6 right tuners, thus the need for a reverse head. I was looking at the KWS to keep costs down, otherwise I'd be all up into another right reverse Explorer neck. I think when the time comes I'll bite the bullet and go RR Explorer or Jackson. Depends on what's in the showcase at the moment. Dang... ???:-\
Super Nigerian Turbo Deluxe Custom said:KainThornn said:Thanks for the replies! Once the end adjuster was set, was there much need for any for any further adjusting via the side adjuster? I'd get a tilt back head type neck or left handed neck just to have the adjuster in a familiar place. I have a set of 6 right tuners, thus the need for a reverse head. I was looking at the KWS to keep costs down, otherwise I'd be all up into another right reverse Explorer neck. I think when the time comes I'll bite the bullet and go RR Explorer or Jackson. Depends on what's in the showcase at the moment. Dang... ???:-\
You're right about the side adjust not being on lefty necks, but a righty reverse is still righty construction as covered in another thread and would still have the side adjust.
Cagey said:It's not like you build a guitar every two weeks.
KainThornn said:RR has nothing to do with where the truss rod is adjusted at, as mentioned before I like the RR hockey heads.
Super Nigerian Turbo Deluxe Custom said:From your post, it made it sound as if an RR neck wouldn't have the side adjust, and it does.
KainThornn said:I'd get a tilt back head type neck or left handed neck just to have the adjuster in a familiar place...
Cagey said:KainThornn said:SS frets are a must have item!
No doubt. It's to the point now where I pick up a guitar that doesn't have them, and for a moment I wonder what's wrong with it. Then, it dawns on me: this thing has pasta for frets! <grin>
They really are the whip. You'll be so pleased once you have a neck outfitted that way, you'll wonder how anyone accepts anything less. Although, to be fair, most people don't get the chance to try them. Few manufacturers are willing to spend the extra $3-$4 material cost to put stainless frets on.
