I know that most all diagrams and instructions will tell you to make your wiring paths as short as possible, because every little bit of extra wiring the (passive) pickup magnets have to push signal through is adding resistance or capacitance. And, I know a lot of people (me) usually leave a bit of extra wire on the pickup leads, because we're liable to change our minds a lot. :dontknow:
BUT: if you look at a regular-sized CTS or Alpha potentiometer, in comparison to their equal-quality "mini" pots, it looks like there's at least twice as much iron in the big ones. Now the outside cases are always "ground" but even inside them, the wipers and discs are larger - why would they make them that big otherwise? I can foresee the point that the larger ones "ought to" wear longer because there's... what - a bit more goo* on the wiper & rotor? But unless you're a heavy-duty Van Halen/Morse little fingerer volume sweller, how often do we really WEAR OUT a pot? Most of the failure is from damage, banging on the shaft or pouring beer into them. And there are now all these pots with a tiny square box on the bottom, the box is usually not much bigger that the shaft of the thing (Bournes is one maker).
I can't find any data (HA HA HA - right! Actual DATA about electric guitar performance? gimme some of what he's smoking!) that details the difference in resistance between, say, a CTS full-size vs. CTS mini pot. It may be there somewhere in the Mouser catalog, but good god. Does anybody know anything about this? And/or, what is the actual output effect of leaving an extra 5" of wire on a pickup - vintage output and/or flamethrowers?
*(forgive my overly-technical vocabulary here)
