They do it on a few models, but they are all CNC programmed and done on the core wood before the lam top is applied. This isn't programmed for the LP bass and would require the use of freehanding with a router.
This is what I wanted, in a flat top and with an existing bridge routing.
I was told this:
Wyliee said:
No such luck with the upper toggle. Apparently, there can be difficulties getting a clean shot with the wiring channel.
