croquet hoop
Let's say I want to achieve something like this:
Considering I'd rather not dye the wood directly and do not have spraying equipment (the best I could use would be a preval unit or rattle cans), here is how I would do it :
- a coat of sealer (tru-oil?) on the top
- masking tape on the binding area
- progressive application of tinted shellac to build the colors to the desired intensity (transtint in shellac)
- final top coats (either nitro cans, KTM-sv or a few more coats of shellac)
The back and sides of the body (swamp ash) would be filled with z-poxy, tinted with shellac to match the edges of the burst, then clear coated.
The reason I'd rather not stain the wood directly is because I'm more comfortable with the idea of building the colors until I get what I want, and I can wipe it entirely with thinner if I mess up, while staining the wood directly leaves, well, stain in the wood, even after sanding.
Plus, I figure that using a coat of sealer will prevent any color from bleeding under the masking tape on the binding area (or that, if it does, scraping would be easier). It will also enhance the figure of the wood (but maybe any transparent finish would anyway?) under the coats of stained shellac.
Any gross misconception on my part? Does this procedure look ok to you, or is there a glaring flaw somewhere ?
