Hello all !
I recently finished this flying V made entirely of parts from warmoth.
I'm happy with everything except the action that is strangely high.
The neck is tensed to the max and the strings are still way too high.
As far as I know, no mistake was made by Warmoth, it all fits together well.
However it really seems that the bridge sits too high by a few millimeter, even though when I compare to another guitar with the same setup, everything looks the same.
Right now the bridge is as low as possible and that brings it flush with the body with strings tensed, exactly as it should.Lower than that the tremolo action suffers.This is about the only place I can adjust, having tried putting the nut higher without real success.
I don't know what to do.I am considering re-drilling the bridge pocket to bring it even lower.
Another strange thing, when the guitar was assembled first, the nut seemed too low for the frets near it, and it was impossible to get a note on the neck.I had to put some wood between the nut and the neck and now it works, but it should work without it ...
-maybe there was a mistake on the nut prep?
-maybe there was a mistake with the bridge prep?
-did I do something wrong?
thank you all !
neck:
KWS, Warmoth Pro , Left Handed Handed, Maple, Purpleheart Fretboard, 1 11/16" Nut Width, Wizard, GD6105 (Gold Color), Schaller (25/64", 11/32") Tuner Ream, 22 frets, 10-16" Compound Radius, No Inlay,Side Dots Only Inlay, L3 Floyd Prep, w/ Mounting Holes, No Finish, 25-1/2 in. Scale, Standard 4 Bolt, Unique Choice: FB374
body:
Standard V, Left handed, Alder, Rear Rout, F-Holes: None, Pickup Rout: (Humbucker (Neck), None (Middle), Humbucker (Brdg))Controls: (X, Volume 1 (V), Volume 2 (V), Tone (V), X, X), , Bridge: Recessed Original Floyd Tremolo, Side Jack: 7/8" (22.23mm) Side Jack Hole, Contoured Heel, Mounting Holes: Standard 4 Bolt, Neck Pocket: Strat® with 720 Mod
thank you all !
neck:
body:
