Mr. Neutron
I'm cutting slots for a Black Tusq Nut blank for my neck. How much clearance between the first fret and the bottom of the strings do most folks set the string height at?
My procedure has been to put a capo between the 2nd & 3rd fret. Then I measure the clearance with a feeler gauge between the bottom of the string and the top of the 1st fret. Sometimes, I skip the capo, and just push down as if fretting a 3rd fret note, but you get the idea.....
I seem to recall something I saw or read once about setting these gaps at, say, .015" or so for the 6th string, and then going down .001 for each successive string; .014" for the A string, .013" for D, .012 for G, and so on......
And I think some folks just set them all at something close to the same gap, thinking to maintain a consistent radius with the fretboard?
What do most of you all do?
