Jumble Jumble
I realised I should probably repost this here, as buried in my build thread isn't a great place for anyone not interested in that build:
So this weekend I fitted the Schaller Sure Claw to the body. It's a very nice part, no doubt.
But sadly I feel I must strongly caution against using it in a Strat body with a middle pickup rout, or with the swimming pool.
When I drilled the holes for the mounting screws, they went straight through into the middle pickup cavity. This gives you a very thin piece of wood to mount the claw to, which isn't great considering the full tension of the strings will be pulling on those screws. The screws that were supplied with the claw protruded into the middle pickup cavity by about half an inch - possibly a little less.
If you were using vintage-style Strat pickups with the classic shape of baseplate (like this) then this completely rules out using the Sure Claw. The two screws would hit the baseplate in the area where the wires are attached. You would have to modify the plate to allow those screws to pass.
In this guitar I am using EMGs which don't go into that area (as seen here). However, that tiny thickness of wood is just not enough grip to mount the tremolo claw, in my opinion. So I needed some other solution.
Fortunately for me, because I was able to use the space where the holes came through, a decent solution presented itself. I got some 4mm machine screws and screwed them through the claw (which they gripped tightly), then through the wood with a new hole drilled at 3.5mm. At this point, because of all the threads in the metal and in the wood, the claw was already quite secure from wriggling - the same as it had been with the supplied wood screws. On top of this I was then able to drop a washer over the bolt from the other side, and tighten a nut securely over the top of that. This gives me a fitting that I am comfortable with. But it wouldn't work at all if I wasn't using EMGs or some other pickup that shape.
I think it's a great design, and I'd recommend it for any guitar with no middle pickup, but for a regular SSS Strat, chances are it's not going to work. "Suitable for all trems" indeed...
