atomheart411
Really not great on a few counts. First and foremost they came with no documentation whatsoever. Granted they seem pretty straight forward to install. But if you've never used locking tuners you might be surprised, as I was, that when you loosen the locking screw to put your first string in nothing happens. Loosen the screw completely and the string hole is still occupied. Spend an hour on the internet trying to trouble shoot and come up empty. Finally find a very poorly translated bit of "instructions top locking screw" on the Schaller German website. "Unscrew the knurled screw on the adjusting axis anti-clockwise until the clamping ball comes off". Ball? What f***ing ball? " Now press the strings against the clamping ball. Under pressure, it recedes. You can now put the guitar string through the adjusting axis." Believe me, I tried to push that string end through a bunch of times before I got to this point. Okay, so if it is a ball in there try pointing the string end up at the very top of the hole. Finally I can see that it's a spring loaded ball. But it's not going to get out of the way unless you're really pointing the string right at the top of the hole.
But you're not done yet ! It took 4 attempts before that ball in there was able to actually secure the high E string. There is NO room for error there folks. I mean really. A tiny ball to grab a hold of an E string? It just kept slipping. Loosen, pull, tighten, slips. Oh yeah, much faster string change. I can just see being in a dark night club and needing to put on an E string. Better have a back up guitar or your band mates are going to very unhappy with you. It was all I could do to resist the temptation to grab a pair of pliers to hog down on the screw. I have large strong hands and no matter how hard I tried to get it tighter it just seemed to reach a point where it was done, and still slipping. Seems like you have to get the string just right in the center of the hole before you can actually get a lock on it.
This my first experience with locking tuners. Instead of feeling more secure I am more paranoid than ever. Really tempted to sell them for a loss on eBay.
