sfguitarworks
SF Guitarworks is San Francisco's largest, best equipped, #1 rated guitar repair shop, and has the skilled staff and precision equipment required to handle any instrument repair, from a quick jack replacement, to a full refret, pickup rewind, extensive custom work, and anything in between. All fretwork is done on our PLEK, a computerized fret leveling tool, which enables us to level the frets to a tolerance of a .0001″, guaranteeing that the guitar will play perfectly all over the neck. We also repair and customize amps and other electronic gear.
All of our work is 100% satisfaction guaranteed, and covered under a lifetime warranty. We deliver top-notch results, and pride ourselves on our customer service. We now have a satellite location in Petaluma where we have pickup/drop-off services available Friday-Monday by appointment.
We also teach setup workshops & partsguitar classes.
Setup Workshop: We teach you the ins and outs of how to perform a truly professional setup, which is much more involved than most people think! You will learn how to accurately assess your guitar, how to cut the nut, adjust your truss rod, set your intonation and much, much more. At the end of the class, you will have a perfectly set up instrument, that you worked on yourself! The workshop runs from 11-3 every few Saturdays in San Francisco & Petaluma, and are limited to 4 students. Availability is always on our website here. Call and register early, as classes fill up fast!
Build Your Own Partsguitar Workshop: This one-of-a-kind workshop will offer you the opportunity to not only learn the skills of soldering, electronics assembly, guitar assembly and final set-up, but to walk out with an amazing guitar custom spec'd and built by you. More information available on our website here.
We have a lot of experience with Warmoth products, and have warranty technicians on staff for Martin, Taylor, Godin, Orange, Fender and more.
We are located at:
323 Potrero Ave (16th and Potrero intersection)
San Francisco, CA 94103
[415] 865-5424
Check out more about us here:
sfguitarworks.com
instagram.com/sfguitarworks
facebook.com/sfguitarworks
If you have any questions, feel free to drop us an e-mail at info@sfguitarworks.com.
