Rounded Fretboard End or Squared
NeilStryker
I've seen both rounded and squared fretboard ends on similar headstock styles.  Is one way standard and the other is special request?  Or does it have to do with the headstock style?  They never asked me what kind of fretboard end when I ordered my neck.
Rounded is standard, if custom-ordering a neck you can specify squared. Once in a while you'll see the odd squared one in the Showcase
Full rounded is standard for Strat type headstocks, you get the rounded corner but flat on the end for Tele type headstocks, and for all tilt backs or conversion necks it's squared end, I believe.
So, could you order a Warmoth Pro neck with the tele style FB (flat w/ rounded corners)?
I believe you can, but I'm sure it's +$45 for hand work, at least, if avaiable
