Replacing Strymon TimeLine Foot Switches
Verne Bunsen
Having made my career on the Operations side of things, I've developed a somewhat cynical attitude regarding the fun that the guys in Engineering must have deliberately designing things in such a way as to make maintenance nearly impossible. I picture them laughing and patting each other on the back as they route a piece of pipe to run 6 inches above a pump motor or put a critical fastener where it can only be reached by a contortionist with an extra joint (and even then they won't be able to get a tool on it because of proximity to other things, HAHAHA!). Every now and again I encounter something that says, "Hey, we put some thought in to this and made it really easy for you to operate and maintain." This was one of those situations. No solder, no dis-assembling and removing other components just to get to the one I'm working on, just a 2-pin connector and easy access. Thanks Strymon!
So, with that out of the way, This here is the Strymon TimeLine I recently bought on Reverb (Etsy?).
It was fully functional, but one of the footswitches was getting a little squirrelly in that it would intermittently fail to register a press. I wasn't too surprised; I knew it was a few years old I'd imagine those switches have been through a lot of cycles. It worked most of the time, just missed enough that I noticed. I saw that Strymon sells replacement switches right on the website, so I snagged three. Might as well do them all. As I said, it's a simple procedure, but I still thought it might be of interest to some so I figured I'd just document it anyhow.
Four screws on the back provide access to the internals.
Each switch connects to the board with a simple 2-pin connector. No clips or other complications, they just slide right off. I should have grabbed a picture of it with the connector removed, but..... I didn't.
If/when you remove the old switch and set it down right next to the new ones, they are conveniently stamped with a lot number that I believe corresponds to the month/year of manufacture. So you don't put the old one back in.
Hole is keyed, switch bushing is keyed, nice.
All three switches replaced in about 20 minutes.
Re-integrated on the board and successfully function tested. The color-coded George L ends sure make it easy to keep the stereo Ins/Outs straight. Also, I topped the new switches off with a set of the BareFoot Buttons "Mini's". I do love the BareFoot Buttons.....
Possibly the easiest electronic repair I have ever executed. I have things where just changing the batteries is harder.
I also have to agree with you about maintenance or repair on some things. It's refreshing to find one that has that figured out in advance. Thumbs up to that manufacturer. It makes you want to do more business with them.
Speaking as a design engineer, I always try to make sure that everything I design is as easy to fix as possible.  This is for two reasons:
1 - something that is fixable will have a long life.
2 - more often than not it's me that's fixing it!
That will do it! Of course truth be told, I've also done the opposite, where you just cram the cover on whatever it is and say, "Man, I hope I never have to go in there again...."
Nice, thanks for sharing.
I like the branding on the board: ”Damage Control Engineering LLC”. It’s always fun when you find these little quirky details. I remember upgrading the eproms in the Kurzweil K2000 synth back in the days. The designers had named the two main boards in there ”Calvin” and ”Hobbes”.
And inside an old Prophet Six (if I remember correctly) they (Dave Smith?) had created pattern in the pcb trace in the shape of a mushroom!  :icon_jokercolor:
It’s kind of a modern equivalent of the writing in the dead wax of an LP. I love that stuff. This is the PCB from a Boomerang III looper:
Awesome!
And speaking of the dead space on LP’s, I remember on one by Kate Bush (or was it a 45?), where she wrote something like ”Congratulations to the black belt, Paddy”. I wish I still had that record ...
