I have to make some dot inlays for a bass and I've been researching. The usual way from scratch is to drill the holes with a bradpoint drill bit that makes a shallow, flat hole, then put in the precut dots. LMII has dots in all different diameters and the drill bits to match:
http://www.lmii.com/CartTwo/thirdproducts.asp?CategoryName=Shell%2FInlay&NameProdHeader=Shell+Dots
http://www.lmii.com/CartTwo/thirdproducts.asp?CategoryName=Shell%2FInlay&NameProdHeader=Chinese+Turquoise+Position+Markers
http://www.lmii.com/CartTwo/thirdproducts.asp?CategoryName=Shell%2FInlay&NameProdHeader=Brad+Pointed+Twist+Drills
There's some books I'm going to request and read from my library (Maryland has a killer interlibrary loan program, you can get
anything).
http://www.artmarquetry.com/Books/art-bk11.html
Search the net for "wood inlay" and "marquetry" and stuff come up:
http://www.inlay.com/marquetry/wood_inlay_part1.html
http://www.marquetry.org/mop_demo_p1.html
I'm going to be staring at those dots the rest of my life, so it seems as though being careful is a good idea. :guitaristgif: I'm pretty sure you could drill out Warmoth's 1/4" (6.35mm) dots more easily than trying to pop them out. The centering punch mark has to be
PERFECT, you know....
