I'm about to buy a neck out of the showcase, and I'm a little confused on the Earvana nut option. Last time I bought a neck, they weren't able to offer these. When I look at the details, it mentions that the nut slot has to be widened to 1/4" to accommodate the Earvana, and that the nut slot has to be filled and re-cut if you want to go back to a regular nut.
What happens if it needs replaced and I want to use another Earvana nut? The drop-in replacements won't work because they're designed for a 1/8" nut slot. Earvana does make an LSR replacement nut that is the same size as the slot Warmoth cuts for a factory Earvana install. Does anyone know if Warmoth widens the slot toward the frets or toward the headstock? I want to make sure that I don't pick an option that would require hacking up the neck if the nut ever needs replaced. I've contacted Warmoth with questions about this, but I think they're a little confused by what I'm asking. Has anyone ever had to replace a factory Earvana on their neck? Thanks.
