Reliced Neck Confusion
NLD09
I've heard of a bunch of guitars with maple necks having stability issues when left without a finish, but when the finish is stripped, either through a relicing process, or naturally over time, i've never heard of any stability issues. What especially comes to mind are the relics or old guitars that a lot of touring guitarists use. It seems like their guitars would especially need a finish going from one climate to another so often, but they continue to play the same guitar night after night without issues. What gives?
Worn out finishes technically get a new finish applied after the paint wears off.  But it's an oil finish, created by your hands as you play.
It generally doesn't wear off in huge chunks so the coverage is usually good enough to keep it stable.  YMMV depending on your body chemistry.
If you're talking about a vintage guitar ('60s or earlier) on which the finish has been actually worn off through playing over the decades you CAN have issues if enough finish is stripped off and the environment is generally humid.
Well, with the Warmoth finish and Maple necks, there is no guarantee of warpage.  There is just a higher percentage of them without a finish do warp, so a hard finish is a good idea.
Also, as other forum members have stated, there is a ridiculously high number of "vintage" guitar necks out there.  More than there should be.  In the 2000s, we're seeing a high circulation of guitars that are 40+ years old, yet in the 60s and 70s, these same make guitars were wornout at only 10 years old.  Conclusion, a lot of "vintage" necks out there are repros.  There's plenty of guys out there that know how to apply waterslide decals and finish necks.
Where is it, exactly, that you hear this stuff? I personally know of a lot of old Fender bass necks warping, but it seems like maple guitar necks hold up pretty well - I've never "heard" of any solid statistical evidence other that what Warmoth says -
Our experience is that hard finished necks seldom warp. Less than 1 out of 200 (0.5%) are returned for warpage. Raw or oiled necks don't fare as well. About 10% are rendered useless from the torture.
In my opinion, the double truss rods used by Warmoth, Schecter and others are probably pretty much invincible, if you're going to run into problems it's almost by definition going to be the single-acting vintage type rods. I cant really conceive of what you could do to a Warmoth modern construction neck that would get the wood to overwhelm the truss rod. And with the degree to which you can do a "satin" type finish with Tru-Oil or very, very thin poly, I can't really understand why raw seems like a good option anyway.  :dontknow:
:party07:
I have a '62 Duo Sonic neck that has most of the finish worn off. And it also has a good twist in it.
Since I don't know of anyone making 22.5" scale necks, I might try my hand at making a neck from scratch on this one.
Rich
I searched warped maple neck in the search box here, as well as online. It's more that I hear of an unfinished maple neck having issues at all, whereas i've never once heard of a reliced neck, or a well used neck having problems ever, even on some of the oldest, most abused guitars ever (SRVs number one, rory gallagher's strat, even the strat jimi hendrix burned was put back together and worked fine). bass guitars are a whole other story though.
I believe that the 24" necks and the 22.5" necks were designed to be interchangeable, i.e. the body wasn't any different. Don't take just my word for it though - there's sure to be some info online.
I think you're right on that, but the kid is 5 now, so 22.5" might be a good start. We can upgrade to 24" later.
Rich
Maybe, but all those guys have guitar techs that can tweak the necks on a daily/weekly/basis....
I kept my first warmoth maple pro neck unfinished for six months or so and it was always straight as an arrow. Who knows if that's meaningful in this convo though. I would be tempted to do it again with a bass neck purchase, seeing as how there's the double truss plus the steel rods in it, but now that I'm living in the NE with the weather changes here I'm a bit more cautious.
I've heard of people having issue with old fender necks warping from travel and weather changes.
