exaN
Hey guys! I put together my first Warmoth many years ago (http://www.unofficialwarmoth.com/index.php?topic=12780.0). I'm now ready to take the plunge once more but I'm a bit out of touch and in need of guidance from you guys. I'm including my shopping list so you guys can take a look, but it's missing some of the electronics. If the guitar will be HSH with DiMarzio Air Classics (bridge and neck) with 1 volume 1 tone, what potentiometers and capacitor would you recommend? Also, if any of you want to spend the time reviewing the list and make sure I didn't mess up anywhere, that would be greatly appreciated too ccasion14:. Thanks in advance!
-BODY:
MODEL: Soloist
WOOD: Alder on Alder
SCALE: 25-1/2"
RIGHT/LEFT: Right handed
ROUT: Rear Rout
PICKUP ROUT: Humbucker (Wood Mount) (N), Strat® (Middle), Humbucker (Wood Mount) (B)
CONTROLS: X-T-T-5 (Strat®)
BRIDGE: Recessed Schaller Floyd Tremolo
JACK ROUT: 3/4" (19mm) Side Jack Hole
F-HOLES: None
NECK POCKET: Strat® Shape
MOUNTING HOLES: Standard 4 Bolt
COUNTOURS: Contoured Heel / Tummy Cut / Forearm Countour
STUD INSTALL: No Stud Install
BATTERY BOX: No Battery Box Rout
BINDING: Ivoroid Binding
TOP FINISH: Black to Clear Burst
BACK FINISH: Black
FINISH TYPE: Satin Finish
-NECK:
MODEL: Modern Construction Warhead
WOOD: Wenge/Indian Rosewood (Dark)
RIGHT/LEFT: Right Handed Reverse
NUT WIDTH: 1-11/16"
NECK PROFILE: Standard thin
FRET SIZE: SS6150 (Stainless)
TUNER REAM: Gotoh/Grover (13/32" 11/32")
INLAYS: Cream Face Dots
SIDE DOTS: White Side Dots
RADIUS: 10-16" Compound
SCALE: 25-1/2"
FRET #: 22
PRE-CUT INSTALLED STRING NUT: R4 Floyd Prep w/ Mounting Holes
-SCHALLER FLOYD ROSE® TREMOLO, CHROME (+ R4 locking nut)
-GOTOH SG38 TUNER, RIGHT SIDE, CHROME x6
-FLAT TOP KNOB, CHROME x2
-SCHALLER STRAP LOCKS, PAIR, CHROME
-FOOTBALL SIDE JACK PLATE, CHROME
-5-WAY BLADE SWITCH
-STRAT® SWITCH KNOB, BLACK
-MONO JACK, BY SWITCHCRAFT
-HUMBUCKER HEIGHT ADJUSTMENT SCREW
-NECK SCREW, SET OF 2+2 FOR CONTOURED HEEL, CHROME
-WIRING KIT
-COPPER SHIELDING TAPE
And what it would roughly look like:
-BODY:
MODEL: Soloist
SCALE: 25-1/2"
ROUT: Rear Rout
F-HOLES: None
BACK FINISH: Black
-NECK:
NUT WIDTH: 1-11/16"
SCALE: 25-1/2"
FRET #: 22
-5-WAY BLADE SWITCH
-WIRING KIT
