M mwbjr13 Junior Member Messages 180 May 5, 2012 #1 Can you float a jazzmaster trem? And if so, how much?
AutoBat Hero Member Messages 3,589 May 5, 2012 #2 Seeing as the Jazzmaster bridge is marketed as Floating, I would assume yes. I don't understand the second question, either it's floating or it's not.
M mwbjr13 Junior Member Messages 180 May 5, 2012 #3 Like with a strat bridge you can set it up so you can use the trem to "bend" up to othr notes. Like how Jeff beck uses his trem.
AutoBat Hero Member Messages 3,589 May 5, 2012 #4 Okay. It's designed to float. I would suggest you look into a Mastery bridge if you're determined to get this setup though.
