This is for my 7 string baritone (still awaiting neck and body from Warmoth). I ordered it routed for 2 humbuckers with the 5 way slot and 3 holes for knobs. I found this diagram for 1V 2T:
http://www.dimarzio.com/sites/default/files/diagrams/2hum1vol2tone_ep1112a.pdf
which will give me:
1. Neck Humbucker
2. Outside Coils Series
3. Neck and Bridge Humbuckers
4. Inside Coils Parallel (no tone control)
5. Bridge Humbucker
Question #1: Would the pickups be in phase in position 3? (see attached photo) My gut says yes because the loop from hot to ground is still counter clockwise in both pickups. But I'm just confused because I've never seen a humbucker wired that way.
Question #2: If I want to swap positions 2 and 4, then all I have to do is swap those lugs when I'm wiring, correct? It almost seems too simple
Thanks in advance for any input!
which will give me:
1. Neck Humbucker
5. Bridge Humbucker
