migetkotla
I've built a large number of Warmoth guitars and still alternate how I design my strats with single coil pickups. I am designing a rear routed strat on Warmoth, and so there will be no pickguard. Do most of you use pickup rings, direct mounted pickups, both......other? I have one guitar that has what appears to be a base below the ring that the pickup sits on.....ordered that a long long time ago so kind of forgot where/when, although it seems to keep the singe coils in place firmly.
Any recommendations for a tried and true way of handling rear routed single coil mounts? Thanks so much......no better advice then what I've read from you guys here. Amazing how it is often very different from other blogs whose members don't actually build guitars but seem to know it all...... Thanks again!
