Mnemoflame
So, this diagram is intended to produce master tone, master volume, all 7 pickup combinations, and series/single coil/parallel bat switches; color-coding is for DiMarzio pickups and is intended to use the opposite pole on the middle pickup from the neck and bridge.
Can someone check this over and make sure I didn't miss anything? The diagram DiMarzio send seems to indicate a ground running from the unoccupied lug of the volume pot to the body of volume pot but it was unclear and I wanted to make sure it was supposed to be that way.
Where are the grounds supposed to go to and what kind of wire should I be using? I have Warmoth's wiring kit (some white, red, black, and braided coax; not a whole lot of each). How is the bridge grounded and what role does it play?
I noted with some irritation that the cap might be on the wrong lug; is that the case?
Uploaded with ImageShack.us
