I've been interested in Warmth for a decade and I think I'm finally close to my first build.
Before you go thinking this is too weird, here's the inspiration of design: http://www.mike-sabre.com/Models/JohnMcLaughlinsModel/johnmclaughlinsmodel.html. Although obviously the look I'm after here is my own taste.
Body:
Model: TELECASTER®
Scale: 25-1/2 IN.
Right/Left: RIGHT HANDED
Wood:
Core: MAHOGANY
Control Cavity: REAR ROUT
Pickup Rout: HUMBUCKER - NONE - NONE
Control Rout:
3 WAY SWITCH (TELE®)
VOLUME (TELE®)
Bridge Type: TREMOLO
Bridge Rout: SEMI-RECESSED WILKINSON TREMOLO
Jack Rout: 3/4" (19MM) SIDE JACK HOLE
Neck Pocket: TELE® SHAPE
Mounting Holes: STANDARD 4 BOLT
Contours:
CONTOURED HEEL
Binding Top: TORTOISE BINDING
Stud Install: USE INSERTS FROM BRIDGE ON ORDER
Top Finish: MARY KAY WHITE
Back Finish: MARY KAY WHITE
Finish Type: SATIN FINISH
Neck:
Style: Vortex
Construction: Gibson® Scale (24-3/4") Conversion Tiltback
Scale: 24-3/4 in. Conversion
Neck Wood:
Shaft Wood: Mahogany
Fretboard Wood: Indian Rosewood
Right/Left: Right Handed
Nut Width: 1-11/16"
Neck Profile: 59 roundback
Radius: 10-16" compound
# of Frets: 22+
Fret Size: 6130
Tuner Ream: Gotoh/Grover (13/32" 11/32")
Inlays:
Inlays: Cream Face Dots
Side Dots: White Side Dots
Pre-Cut Installed String Nut: GraphTech White TUSQ XL - Standard Nut
Finish: Clear Satin Nitro
Binding: Tortoise
Open to suggestions or any possible pitfalls here.
Controls: the switch will be simple on/off for the humbucker (no volume pot) with possible a few different cap options, and then a tone pot.
Also, one specific question is that I saw in the "in-stock" section they offer super lightweight mahogany bodies. How would I order that for my build and how much extra does it cost?
Body:
Model: TELECASTER®
Scale: 25-1/2 IN.
Wood:
Core: MAHOGANY
Control Rout:
VOLUME (TELE®)
Contours:
CONTOURED HEEL
Neck:
Style: Vortex
Neck Wood:
Nut Width: 1-11/16"
# of Frets: 22+
Fret Size: 6130
Inlays:
Binding: Tortoise
