MikeW
I've got a Swamp Ash, top rout S-S-S, with a recessed Schaller Floyd rout that I'm not going to be using anymore. I'd like to pass it along to someone who will use it.
This guitar was my everyday player for about 5 years and was gigged a couple times a month over that period so it's got some good use. There are the standard chips in the back and near the forearm contour but the finish on the front is still in good shape. As I remember it was a two-piece Swamp Ash body that weighed in at just about 4 lbs. With the recessed Floyd rout it's probably just under that now. It's got a contoured heel as well.
I've also got the Schaller Floyd bridge, springs, trem claw, inserts and posts that I will pass along also. It's in black.
There's a 7/8" jack with a black football plate installed in the body already that I'm going to leave there as well.
I've got a 500k long-shaft tone pot with a .047 cap already in place and a 500k long-shaft blender pot that were both in this guitar when I took it apart.
I've got the neck mounting screws for the contoured heel, but I'm going to be using the neckplate.
The control cavity cover is still in good shape and the cover holes in the body are not stripped.
Here's the kicker for the deal. I'm willing to part with the body, the bridge, the jack and plate, and the miscellaneous hardware for $50 to $100. I'll take shipping out of that. First offer takes it.
Let me know what parts you want and/or don't want and I'll package it up and send it your way. Here's some pics of the stuff that I mention above.
The white Strat before:
Body after disassembly:
Jack and plate:
Misc Hardware:
Edit: While I was sifting through my old parts box I found a couple other things that I'll include:
1. I found an old R2 Floyd nut in (kinda) black. It's really old and I don't recall where I got it but I'll include it if you want it.
2. String retainer bar matching the nut.
3. I've got six original Floyd saddles with the saddle lock bolt and the string holder bolt. The little blocks that go inside are missing though.
4. I also found a short-shaft 500k volume pot that I'll pass along if you want it.
Jack and plate:
Misc Hardware:
