pwrmac7600
So I recently completed my build of my Warmoth Tele Deluxe, and I am now questions my neck choices.
On the build I ended up going with a showcase neck that was 1 5/8th nut width with a standard thin contour and 10"-16" compound radius.
Originally I was going to go with the 59 roundback contour, as the majority of my other guitars are Les Pauls, the most comfortable of which all have 59 profile necks.
The issue I am having is I am getting cramping in my thumb when playing any type of barre chords. I just can't figure out if it is the smaller profile, or the smaller nut width that is causing this.
My debate was to go back and reorder a new neck that was 1 11/16th with a 59 round back profile since it is pretty much what I am used to. But then again I have a few Solar guitars which are 1 11/16th and more of a wizard profile, and these feel really comfortable to me as well. Which starts to make mean lean more towards the fact that it my be the nut width that is causing my cramping?
I don't really feel the radius has anything to do with this issue as my Les Pauls are all 12" radius, and my Solar guitars are 16" radius, and I feel no discomfort switching between then whatsoever.
Thoughts? Suggestions?
Thanks!
Thanks!
